Can I re-use my TFI
Discussion in 'Engine, Fuel and Exhaust' started by robermv32, May 9, 2010.
  1. robermv32
    robermv32 Active Member
    254
    I have a 2008 FXSTC that I've put 25,000 miles on. I'm thinking of moving into the Touring class and am looking at the 2010 Road King or Street Glide. My question is this. Can I transfer the TFI from my Softail Custom to either of these new bikes ?
  2. Bud White
    3,270
    check the part # for the bike its on and the bike its going to ..
  3. BUBBIE
    BUBBIE Well-Known Member
    4,974
    125
    Go to dobecks TFI site, dobeckperformance.com Look at the different models and see if the part numbers cross-reference.. that will tell you if you can or not.
    website is open 24/7 /open hours m-f normal business times/ central time? montana.
    see Bud White beat me to the punch
  4. glider
    50
    Your softail uses a 1250ST while the 2010 touring uses the 1254ST. Call Doebeck and speak to Chris. They have a program so you can update to the newer model for minimal cost.
    877-764-3337
  5. walleye
    walleye Junior Member Contributor
    944
    3
    BUBBIE: Just so you know.....Montana is Mountain Time.:D
    As far as Dobeck, as Glider says, they are the best. 1st class all the way and they will take care of you.:s
  6. glenalt
    glenalt Junior Member
    406
    36
    When I checked with Doebeck about it on mine he said all the units were the same, it's the connectors that are different. Call em.
  7. BUBBIE
    4,974
    125
    Dittos on above!
    I Knew that, just didn't come out the fingers.. Thanks WALL-"EYE"
    Your a lot like like Glider "SEES ALL"
