G gec1995 Member Apr 7, 2011 #1 Can you tell me if you can use a ultima coil with a crane ignition module.Thanks
J Jack Klarich Guest Apr 7, 2011 #2 As long as the Ohm values are correct and it is for single fire or dual fire depending on your set up :s
G gec1995 Member Apr 7, 2011 #3 Jack Klarich said: As long as the Ohm values are correct and it is for single fire or dual fire depending on your set up :s Click to expand... thank you the 2.4 ohm is good and is single fire put the ultima coil on with the crane hi4 ignition module and works real good Last edited by a moderator: Apr 11, 2011
J Jack Klarich Guest Apr 11, 2011 #4 gec1995 said: put the ultima coil on with the crane hi4 ignition module and works real good Click to expand... Good Deal now put some miles on and Smile
