Camshft question
Discussion in 'Softail Models' started by Veep, Aug 11, 2010.
  1. Veep
    Veep Member
    I ride an 09 nightrain with V&H big Shots, air cleaner, and SE 204 cams. I am not really happy with the cams. They seem to perform well above 3000 rpm but poorly at cruising speeds. If my rpm is below 2500 rpm and I roll on the throttle it vibrates noticeably until rpms increase and then it takes off quickly. Would a cam advance kit make a big difference (to lower the effective RPM range of the cam) and who makes a good one. How much should I expect the RPM range to drop. Or would a new cam be the way to go. I am not doing any head or valve work so no high lift cams. Any suggestions or comments would be welcome. Thanks. :newsmile091:
  2. rancid
    rancid Active Member
    257
    i think if its struggling around 2500 then cleans out and pulls hard you may want to look at the tuning side of things as a cam profile wont come in hard like that. what tuner are you using??
  3. eleft36
    eleft36 Junior Member
    441
    Put the stock mufflers back on if you want low end torque.
    Al
    :USA
    :CONNECTICUT
  4. Veep
    Veep Member
    I am using a SERT and had the bike dyno tuned at my local harley dealer.
  5. Breeze3at
    Breeze3at Well-Known Member
    4,923
    224
    You state, performs poorly at cruising speed/2500 rpm. If you are rolling on hard in 5th gear at 2500 rpm, you really shouldn't expect much until you get above 3000. It's not so much the cams, as the gear ratio. Higher gears don't have the mechanical advantage that lower ones do. If your bike doesn't pull well from 2500 in 3rd gear, you have a concern.
  6. 98fat
    98fat Active Member
    136
    Very few cams do much prior to 3000 rpm most above 3500 rpm. Exhaust will make a huge difference below 3500. I was running Vance big shots with no baffle. Went to a two into one with baffles. Big difference.
  7. R.Bingham
    R.Bingham Active Member
    317
    4
    A +4 degree advannce will move the power band to come on about 500rpm sooner. The 204 is a good cam but Joe Minton from American Rider magazine recomends using the +4 advance for street use.He always recomends a cam with an intake close of 30 degrees after bottom dead center. The 4 degree advance will acomplish that with your cam. I believe Andrews makes one.
    [​IMG]
  8. R.Bingham
    317
    4
