camshaft cover broken bolt
Discussion in 'Other Service and Maintenance' started by fabrozor, May 29, 2014.
  1. fabrozor
    fabrozor Active Member
    237
    hi,
    On my FLHT 2005, a camshaft cover bolt has broken.
    There are only few threads remaining.
    The bolt was installed with blue loctite.
    How would you remove it ???
    I think to heat with a flame but i'm affraid to put the fire onto the whole bike.
    Here are 2 photos to show the bolt on top right.
    Thanks.
  2. hillbilly81
    hillbilly81 Active Member
    368
    you should be ok putting some heat to it..looks like you have some threads to grab hold on
  3. Jack Klarich
    Try a heat gun, you may also use a piece of pipe that will fit over the broken bolt and give the surface a few taps before removal
  4. TQuentin1
    4,737
    142
    If you have a pair of needle nose locking pliers, it looks like you have plenty of thread left to get a grip on (see below). My guess is that once you get a little movement, it will get handy.
    Eclipse 6 Needle Nose Locking Pliers
    Once removed, chase the threads in the block with a tap (I think those are 1/4-20, but double check). Has to be a reason that the old bolt got so stuck it sheared off.
    Cheers,
  5. fin_676
    5,788
    153
    287
  6. Jack Klarich
    Those are Awesome tools, I have American and Mteric set, I bought mine years ago when they first came out, Now they can be had cheap at many discount tool outlets, if you break a stud they will pay for them selves:D
  7. fabrozor
    237
    Thank you guys for the advices.
    I think i'll try to heat with flame and gently hit the end of the thread with a hammer.
    Then i will try to buy 2 nuts and thread it with Red Loctite, so it should be more stiff than the blue Loctite and it should unscrew.
  8. DFHarley19
    DFHarley19 Active Member
    390
    I can see that you could remove that stud easily (I hope so!). Take a look into that video and you will be able to do that. Let us know how you make it.
    How to remove a stud - YouTube
  9. WildWes72
    WildWes72 New Member
    3
    Get a small pair of vice grips and apply heat and slowly work it out. It should not take much to get it out!!!
  10. fabrozor
    237
    Hi,
    I tried to put 2 nuts on the bolt remaining few threads and tighten them together + some loctite.
    It didn't worked. The 2 nuts unscrew together out of the bolt.
    Now i put 1 nut on the bolt + loctite, then i hammered the bolt external end to flaten it onto the nut.
    I let the loctite become dry and stiff. I'll try tomorrow to unscrew the whole thing.
