hey brothers, I was wondering if anyone has installed a S&S Cycle 570GE Easy Start Gear Drive Camshaft Kit in their bike. was it much improvement over stock. what was your overall opinion, thank a lot.
sorry for the lack of info, My ride is a 03 FLSTS.milled the heads,free flow exhaust,carb rejetted and plastic slide drilled,screaming eagle ignition, crane 316-3 cams. it does well but just like the army says, be the best you can be, with the milling the compression is 9.9. so you think its worth it.
Thanks dolt, my head gasket is .030 with stock pistons in an 88b motor. I really like the 316 cam but I want to go gear drive. I can mill another .020 from the head and was planning to do so if I put this cam in and change the valve springs.
Problem I sorta see with the Easy Start cams is, how will you do a compression if you need to? JMHO.![]()
