J
Jack Klarich
Guest
A good product for any garage, can be found at Home Depot and many hardware stores
PRODUCT OVERVIEW
Model # 084107N
Internet # 206513469
Store SKU # 684489
Liquid Electrical Tape (LET) is easy to use, providing an airtight, waterproof, dielectric coating in minutes. The coating will last for the life of the application, yet it can be removed immediately as needed. 1 application will protect terminal connections or splices, as well as guard against vibrations that can loosen connections. Star Brite Liquid Tape is UL-tested, easy to use and reliable. Stir well before using. Wires or terminal to be sealed must be clean and dry. Brush or dip Star Brite Liquid Electrical Tape on electrical connection area. Allow to dry for 5 minutes and apply second coat if greater thickness of seal is needed. Succeeding coats may be applied at 5 minute intervals to build up extremely thick protection. Product fully cures in 24 hours.
Here is the info on the above product from Home Depot web page
- Forms an airtight, protective, waterproof, UV resistant, dielectric coating
- Prevents corrosion on wires and terminals, protects against vibration
- 100âs of uses - bilge pumps, outdoor exposed wiring, sprinkler pumps, timers, underground wiring, outdoor lighting fixtures and instruments, anywhere a weatherproof and dependable connection is needed
- Stops terminal screws from loosening due to vibration
- Will not peel or unravel
- Service range -30°F to +255°F
