brake light problem
Discussion in 'Electrical' started by nascar7613, Apr 12, 2010.
  1. nascar7613
    nascar7613 Active Member
    241
    38
    5
    08 Street Glide. When the rear brake is applied the brake light comes on but does not immediately go off when the brake is released, it takes a few seconds. When this happens, it also makes the check engine light come on. The brake light works fine off the front brake.
  2. Hoople
    Hoople Account Removed
    7,198
    34
    This all happens when bike is at rest? Strange. What error does it post. You can clear error and it will re-post same error when brake light hangs.
  3. glider
    Possibly a defective brake light switch. Follow the brake line from the rear master cylinder and in the line you will find the pressure switch that operates the brake light from the foot brake.
  4. Hoople
    7,198
    34
    Glider, is that an ABS code? I don't know what year ABS became available for HD.
  5. glider
    What code? They were first on the 08 bikes I believe.
    Check here at the bottom for the ABS codes...
    09-08-07 DTC Codes - Harley Davidson Community
  6. Hoople
    7,198
    34
    OP said "check engine light" came on. Maybe it is not storing a code at all or I am reading too deep into problem. But it is an '08 bike.
  7. glider
    Thought I missed the code somewhere :D
  8. nascar7613
    241
    38
    5
    It does not throw a code. It just makes the check engine light come on.
  9. glider
    Usually with the light on a code will be present, have you tried to locate a code?
