charleyhorse
Has anyone ever had a problem with the front brake serging are jumping (don't quite know how to discribe it) when you stop at low speeds? Is this a wraped rotor ar what? And how did you fix it?
Sounds like a warped rotor, unfortunately the only fix is to replace it.![]()
My limited brakes started chattering at about 12000 miles - checked rotor run-out. .011 on right front, .004 left front. Took to dealer - they replaced right front rotor under warranty. New rotor is .002. Fixed the problem.
