Thor86
Ok this has stumped everyone I know. I just got a 04 Road King. The fuel pump and ECM fuse were blown so I replaced them and as soon as I turn the ignition on the pump blew again. Sometimes its the pump fuse and sometimes the ECM never both at once. Here is where the fun begins! If I unplug the pump at the top of the tank the fuses are fine. I checked the wires in the tank and they check out and also put a new pump in. But still blows fuses. Now ive pulled the tank and checked over the harness and found no issues. Set the tank back on plugged the pump in and the fuses were fine. BUT! If I put a single mounting bolt on the tank just finger tight the fuses pop. No bolts and fuses are fine. Please help!!!
