blinker problem
Discussion in 'Softail Models' started by trnman32, Aug 28, 2010.
  1. trnman32
    trnman32 Member
    20
    When I purchased my bike the previous owner removed the front blinkers,and when you turn the rear blinkers on right or left it blows the fuse to all the dash instruments. Its a 2006 fatboy any help would be greatly appreciated.
  2. TQuentin1
    4,737
    142
    Dead short somewhere. Track it down.
  3. 2000classic
    2000classic Active Member
    301
    I would be checking the wiring harness under the rear fender, above the wheel.:s
  4. Jack Klarich
    Find where the wires are cut that should be the dead short TQ suggested, make sure with a test light:D
  5. NEWHD74FAN
    8,191
    98
    19
    If the previous owner just "amputated" the wires and removed the hardware, you could have loose wiring. If he "wrapped and insulated" or pinched wires in the process, you will see this...be sure to check the wire looms and passthru areas in the fork area and rear fender wiring areas as well. Simple DMM using voltage checks or preferrably using unpowered bike and ohmmeter (continuity/shorts) checks. Suitable DMM can be had for under $5 at Harbor Freight.
