free website stats program Bench Testing a Coil | Harley Davidson Forums
J
Jack Klarich
Guest
If you want to "bench" test a coil, remove wires, attach a hot 12 volt to the battery (batt, +, etc.) terminal. Then attach a wire to the ignition (ign) terminal and touch ground and remove. Should throw a spark from the high tension lead with each application of 12v and removal. The ground wire basically imitates the function of the ignition points/module. If the high tension lead terminal is gapped a reasonable amount from the engine, there should be a bright white spark. Weak or orange spark indicates (low voltage...or) bad coil output.
Good reminder Jack sometimes we forget about the simple tests in these days of the computer knows best
You can also check youself for continuity to ground with the coil output wire. jjuusstt be sure your pants aren't wet.
