B BigG Active Member Jul 23, 2009 #1 Is there a quick and easy way to check belt tension for proper tightness? Is it better to be too tight, or too loose?
G glider Veteran Member Jul 23, 2009 #2 There's a tool made for checking the 10 LBS necessary to properly adjust a belt. It's available at the dealers.
speedyron Active Member Jul 23, 2009 #3 The Amount of tension is listed in your manual. It is not good to have it too loose or too tight.
