G gn5rivers New Member Sep 3, 2009 #1 Is there a trick to removing the Deuce, inside rear belt guard? I hope I'm wrong but it looks like I have to remove the rear wheel. Thanks gn
TQuentin1 Well-Known Member Staff member Moderator Sep 3, 2009 #2 gn5rivers said: Is there a trick to removing the Deuce, inside rear belt guard? I hope I'm wrong but it looks like I have to remove the rear wheel. Thanks gn Click to expand... I removed mine, and do not remember having to remove the wheel to do so. Make sure you have found all the fasteners and removed them. TQ
G gn5rivers New Member Sep 7, 2009 #4 OK Thanks. the lower rear bolt seams to be part of the plastic guard, the head's not accessable, it seams to be molded into the plastic. I'll try to figure out how to remove it. G
