Anyone know the crank Timken bearing numbers (non Harley numbers) and perhaps the bearing on the right side as well? I can order bearings for wholesale directly but need the actual number to do that? Thanks:laugh
I think the left side is the only one that can be changed, they have a upgraded bearing they call a LEFTY but I'm not sure of the part# and theres no inner race with it. good luck
Are you shure what bearings come with the flywheels or not? Here's a parts bulletin on 03 & later install, sounds like you keep the good bearings being 00. View attachment Stroker Flywheels 2003 PAB732.pdf
Hi Chopper
Hmm well the Harley kits that I have bought up to now were great for supplying everything but not sure about the crank assy as they don't mention bearings (other then that if you have a 2003 or later you have to convert it?)
