free website stats program Battery Removal | Harley Davidson Forums
Battery Removal
glider.
BOT Machine
Many have asked the proper way to remove a battery from the bike.
If you remove the negative terminal first and install it last, you have no worries about shorting out the wrench.
When you pull the negative first, it opens the circuit to the battery and if you should ground out the wrench pulling the positive cable, there will be no sparks and welded wrenches.
Remember if you have an alarm system to turn on the ignition first and pull the maxi fuse or the siren will go off.
