Battery Removal
Discussion in 'Softail Models' started by albie, Aug 25, 2009.
  1. albie
    albie New Member
    Hello,
    I'm new to the group.
    I have a 2007 fatboy.
    I'm trying to wire in a digital clock.
    This may be a stupid question but,
    Is there an easy way to remove the battery?
    Everything is packed in so tight around the battery and
    I'm afraid I will break something or rip some wire(s) out.
    Thanks, Albie
  2. R. Lewis
    2,183
    5
    Have you checked out the self help section on here yet ? Might be some info there!!
  3. Hill202
    Hill202 Active Member Contributor
    245
  4. albie
    albie New Member
    Thanks for the tips.
    I'm still searching the self help.
    The posting you pointed to about using substitute bolts for leverage
    sounds good but it won't work in this case.
    I can barely get the tips of my fingers on the battery.
    They should have a plastic strap around the battery so you can just lift it up.
    Anyway, still looking.
    albie
  5. wildspirit97
    wildspirit97 Senior Member
    1,088
    46
    you could try something like this Amazon.com: Kastar B600 Heavy Duty Battery Carrier: Automotive if you can't lift it out. I Think it would work, but I've never tried it myself.
  6. glider
    How about an old leather belt and run the bolts through it on the both battery terminals.
    Please don't improvise here and use a piece of wire in place of the belt.:bigsmiley22:
  7. whatyardwork
    whatyardwork Banned
    829
    4
    Actualy have a couple of Chevy/GMC forward fender cross braces for this.Got them from wrecks over the years.A little electrical tape and an extra sheet of heat shrink tubing has turned them into excellent battery pullers.
    Disconnect the cables and bolt these straight up for handles.Works great.
  8. glider
    NOT connected together either.:52:
  9. whatyardwork
    whatyardwork Banned
    829
    4
    No, the GM trucks have a cross brace to the core support since the late 80's.A stiff rod with flattened out ends to connect the fender to the core support with 13mm bolts.Realy a perfect handle for pulling a battery.
    Because they flattened out the end and slotted it to except a bolt,you can use the origional battery bolt.
    Each end is flattend to accept a bolt.Cut it in half and you have 2 handles to pull your battery.
