Battery Not Charging
Discussion in 'Electrical' started by neadaporsh, Sep 24, 2009.
  1. neadaporsh
    neadaporsh Member
    12
    My 1986 FXRS is not keeping the battery charged. I rode about 60 miles today and stopped for a cold one. When I tried to start my bike the battery was DEAD. I got a jump start and rode home. Bike ran fine, but when I got home the battery was still dead. I put a charge on the battery and it held a charge fine and checked out fine. Any help in solving this problem would be geatly appreciated.
  2. SpringerSteve98
    SpringerSteve98 Active Member
    187
    Its one of two things. The stator, or the voltage regulator. I'd start with opening up the inspection cover on the primary... See if it smells like burnt wires. If there is no stink, test the stator and the voltage regulator with a multimeter. Here is a link that explains it far better than i can. Testing The Charging System - Harley Davidson Community
  3. TQuentin1
    4,737
    142
    I think SPRINGERSTEVE98 has you covered, but depending on how old it is, I would pull the battery and take it to Hi/Lo or AutoZone and have it checked out first. Sounds suspicious to me.
  4. kemo
    kemo R.I.P
    1,690
    5
    Maybe your bike is telling you not to drink and drive.
  5. kman
    kman Member
    40
    Check, your stater plug... It may have come loose or shorted out. Happened to me once and after replacing I used clear silicone to secure the new one.
  6. glider
    Excellent suggestion and a problem on the evo engines.
    Stator Plug Retainer - Harley Davidson Community
  7. Breeze3at
    Breeze3at Well-Known Member
    4,926
    224
    I think the FIRST thing you should do is check the voltage at the battery when it's running. You should be getting about 13-14 v. If you are getting voltage there, then suspect the battery. If less than 13v, suspect things upstream, like plug in, voltage reg, stator, etc.
  8. dangerdan
    dangerdan Junior Member
    922
    I would to add to the following posts
    I had the same issue on my 95 with a brand new Oddessy battery.
    The battery charged great on the battery tender, but trying to start was hit and miss. I had the battery load tested and it was good.
    I replaced all 3 battery cables and never had a problem since.
    I see you have an 86. If you have never changed or cleaned the battery cables , now might be a good time.
  9. NEWHD74FAN
    8,191
    98
    19
    DD...I think there was an issue about using a Battery Tender w/ an Oddessy type battery...think it was not enough charge current/voltage...maybe TQ can bring some light on the subject.
  10. Davidw2415
    Davidw2415 Senior Member
    1,456
    46
    Glider, for those of us that don't know, would you explain the stater? What, where and what it does.
