Battery and check engine light
Discussion in 'Electrical' started by dwlaycock, Jul 19, 2015.
  1. dwlaycock
    dwlaycock New Member
    I have a 2010 ultra w/38,000 miles on it, the other day my check engine light and batter light came on while drive, noticed my voltage had dropped to just over 10v but bike was still running fine with no apparent problems. Got home and after letting it sit for an hr or so it started right up, no lights and voltage came up. Now today after riding for a while it did the same thing, check some forums and got the following codes of the speedo: b 1008, C 1095, C1216. They dont seem to have anything to do with electrical/charging system. I am assuming either my battery, voltage regulator or stator are going bad? Any ideas, suggestions?
    Thanks if advance
  2. Jeff Klarich
    4,842
    103
    496
    It could be any of the 3, check in the self help section on how to diagnose each one and you'll most likely find the problem.
  3. Bodeen
    4,647
    73
    222
  4. dwlaycock
    Thanks for the help, I found the problem...the stator war fried, replaced it and now im off to Sturgis on Friday :)
  5. Jeff Klarich
    4,842
    103
    496
    Good find, ride safe.:s
