Base gasket-1990 Evo.
Discussion in 'FXR Models' started by Jonk777, Sep 25, 2014.
  1. Jonk777
    Jonk777 Member
    39
    Are there anybody familiar to a Base gasket by-pass pigtail kit. Is there any benefit to it. Is it easy to perform a repair using the kit. How much of a performance gain. Would it keep the oil up on the rockers more. I need more insight into this.
  2. Breeze3at
    Breeze3at Well-Known Member
    4,926
    224
    Several of my friends used them in the 90's with good results. There used to be several different brands, but all on the same principal. It won't keep any more oil in the top end, it just keeps oil from seeping thru the imperfect case/cylinder surfaces. I've lived with the oil spot on my front cylinder base so long I think I would miss it.
  3. Jonk777
    Jonk777 Member
    39
    Thanks , Like Lynard S, says that's why they call him the Breeze.
  4. Jack Klarich
    Good products, I also used copper gaskets and steel multi layered head gaskets dressed them with a file and used spray copper coat and never had a leak
