Badlands does it again!
Discussion in 'Touring Models' started by gabe cestaro jr, Aug 27, 2009.
  1. gabe cestaro jr
    gabe cestaro jr Member
    15
    Today Dan from badlands talked me threw making my tour- pak rear and side lights run brake and turn i have a 1ll-01-a control module doing more then just the rear turn signals and aim very pleased
    thanks Dan
    Gabe
    2009 ultra
  2. crimedog
    crimedog Member
    9
    what did you have to do extra besides the module to get the tour pak to run turn signals...
  3. gabe cestaro jr
    15
    two wires and some connectors and i had 2 led bulbs around
  4. glider
    Gonna let us in on HOW you did it? :D
  5. gabe cestaro jr
    15
    coming out of tour pak light you have 3 wires out of each light leave the black alone and take the other 2 put them together and run a single wire back to module conector coming out of module found your right and left single wire or your brake and turn wires tap them in now for side marker the single wire you ran back you tap that wire off side ligths again not the black wire
    hope this helps have to go look the colors up on module or if you have a 1ll-01-a module give them a call it took about 15 minutes
    thanks gabe ps i had some led lights i used in tour pak
  6. FFreer
    FFreer New Member
    3
    Gabe...
    What is the web address (URL) for Badlands? Sounds like they were really helpful.
    In advance, thanks
    Fred
