free website stats program Bad electrical | Harley Davidson Forums
Bad electrical
feederdrvr
I have a 2006 Heritage.Today the speedometer ,horn and signals stopped working.Bike runs fine.When I started it back,flashers flashed 6 times.Things are tight here.Any suggestions on the fix and cost.Thanks
Thanks.I found where the wire to the front fender lamp had come in contact with tire causeing bare wires.I spliced them together.Would this cause the speedometer,horn and flashers not to work?I tried to perform code test and speedometer test,but i must be doing it wrong.Will spliceing wires not fix problem or if it did do codes need to be cleared?
Splicing the wires will not cause a problem. If the problem was just that wire, the code lamp should go out after 50 start/ run cycles if it doesn't set another code from something else.
Check your fuses.
