back lights???
Discussion in 'General Harley Davidson Topic' started by lannett, Sep 23, 2015.
  1. lannett
    lannett New Member
    went to chaNGE back lights now only one works????WHY and break light wont spart???:(
  2. Jeff Klarich
    4,806
    103
    487
    Bad bulb? did you check the fuses? did they work before? did you replace with LED bulbs? a short somewhere? clean the sockets and make sure bulbs are seated.
    Just a few things to check.
  3. HDDon
    5,544
    133
    229
    What type of lights did you change to? Check under the rear fender for wires that have been rubbed through or are shorting out.
  4. gator508
    gator508 Well-Known Member
    2,762
    179
    Swap bulbs, you may have a bad one.
