IF you are really careful,,,,,,, a clamp-plier might do the job..(*) below
IF I had it, I'd use a nut on it and Weld it inside the hole... Must cool off theen lightly turn each way to start it moving....
(I am an Old welder and using the proper .030 wire S-6 wire, I do and did this all the time)
Now IF you use the clamping jaw type plier,,,,
Thinking a little heat on the aluminum???
some Faint at that suggestion.....:small3d031:
