Auxillary switch connector
Discussion in 'Electrical' started by Deederx, Jan 21, 2014.
  1. Deederx
    Deederx Member
    5
    I want to add asscesory that would only be on with aux switch in on position.There are connectors under seat on my 2009 ultra classic electrica glide.Will one of these do that.And polease don't suggest one of those cigratte cables.
  2. Slo-Ryd
    Slo-Ryd Junior Member Contributor
    527
    23
    Ignition only in Aux or "Aux and Run" ??...I don't think there's anything that only gets power in aux position only. If you mean the rocker switch then yes, under the seat there should be a deutsch connector controlled by that switch.
  3. Breeze3at
    Breeze3at Well-Known Member
    4,926
    224
    Your fairing skirt rocker switch has a connector, with a rubber cap on it. It was in front of battery up until 2008, now I don't know where it is, but probably not far away. HD makes several connectors, 70264-94A is for '94-'13 touring I think. They also make one with the thing on the end you said not to suggest, so I won't. :D
  4. jimharvey1
    jimharvey1 Junior Member
    469
    9
    Pin 3 on the accessory plug under the seat (orange wire) is controlled by the rocker switch. Pin 4 (black) is your ground.
  5. Deederx
    Deederx Member
    5
    Thanks guys this helped
