Auxillary Lamp Bulbs
Discussion in 'Electrical' started by mc2, Sep 3, 2011.
  1. mc2
    mc2 Active Member Contributor
    266
    I have replaced to many halogen auxillary lamps, courtesy of the vietnam dept of hiways. They just don't take the beating. Headlamp holds up fine.
    After cutting away the outer rubber cover I find the bulb is held in place with a very efficient "looking" rubber assembly. 3 screws remove this and releasing a clip the bulb with lead wire is simply removed.
    Does anyone offer this simple bulb for replacement? With a sharp object, some surgical skills and a little silicone, the rubber cover could be replaced. I expect it to be a bankroll cheaper than $60 for a full lamp. I got a lot of hiway and byway to travel yet and depend on this additional lighting.
    I do appreciate any leads or contacts on this.
    Mike
  2. Iceman24
    Iceman24 Well-Known Member
    3,266
    23
    Good question...replacement elements gotta be available somewhere. I'd say they're probably a tad more durable than regular household type. Did you try a internet search & see if anything matches?
  3. Hoople
    Hoople Account Removed
    7,198
    34
    Probably. But without pictures or dimensions, don't know if it is a custom made bulb. It can be but most likly is not.
  4. wilks3
    wilks3 Junior Member
    623
    Look for a bulb that has same basic number but with LL in front. i.e. LL3157. LL means Long Life, they are used in heavy duty rough useage applications, semi's, dumptrucks, etc.
    I believe if you would call a light company, GE/Sylvania, they could cross reference one for you.
    wilks3
    :USA
  5. harley@16
    harley@16 Junior Member
    483
    5
    is that the same as the passing lamps on touring bikes?
  6. mc2
    266
    I believe this is different from the touring bike passing lamps.
    This was my first step in research, and will now be expanding. Some things are a little more challenging from VN with the time differences.
    Will post any news.
    Thanks for the comments.
