Any tips for removing "Batwing Fairing"
Discussion in 'Other Service and Maintenance' started by lakeforktx, Dec 3, 2010.
  1. lakeforktx
    lakeforktx Active Member
    229
    I have never removed my fairing before, going to be installing my new 80/100 bulb from GermanAuto this weekend, Are there any things to do to make it go better ? and anything not to do ? That you have learned the hard way...Thanks for the input........................:small3d007:
  2. dbmg
    dbmg Guest
  3. lakeforktx
    229
    re: Any tips for removing "Batwing Fairing"
    I see ... that will be very helpful.. thanks a lot...
  4. dbmg
    dbmg Guest
    In regards to Tanks post...Naw...Its just when you have nothing to do and all day to do it. Can't ride anymore bikes been put to sleep. So like I told the Southern guys you South Western guys need to keep the ride alive for us snow folk........:57:
    Your welcome. Not that hard really. Just be prepared to unplug headlight before removing fairing all the way and plug headlight in first.......
  5. lakeforktx
    229
    No problem there ,,it was like 75*s today would have been a great day to be out riding.. but keep in mind when it's real nice up there this summer and ya'll are out riding.. It's hotter than you know what down here. can't ride when it's 105*s without frying....
  6. Breeze3at
    Breeze3at Well-Known Member
    4,926
    224
    While you have the fairing off, you might want to tape some insulation to the fairing right behind the speakers. Any insulation will work, it will improve sound of your speakers a bit. Also inspect the fairing mounting brackets for cracks.
  7. lakeforktx
    229
    Will look into that for sure.....
  8. cool breeze
    cool breeze Active Member
    147
    it sounds like your just replacing your head lite bulb why take off your fairing?
  9. lakeforktx
    229
    Can you replace the headlight bulb with out removeing the outside Fairing ? And I need to clean the milky haze from the iside of the glass...
  10. NEWHD74FAN
    8,191
    98
    19
    Might want to check the service manual to see if you can access and remove the escutcheon and cover without removing the fairing...but you might be right if there are no access or trim cover hiding the fasteners.:s
