Analog Dipstick Problems (P/N 62896-00B)
Discussion in 'Softail Models' started by MilitaryMike, Nov 3, 2010.
  1. MilitaryMike
    MilitaryMike Member
    76
    I purchased the Analog dipstick (P/N 62896-00B) for my '08 Heritage over 1-1/2 years ago and now it falls out when starting the bike, cracking the throttle and/or going over major bumps.
    Is it possible that the dipstick shaft is too long and connecting with other moving parts which causes this to happen?
  2. HarryB737
    HarryB737 Junior Member
    656
    Try drying off the rubber right below the gauge when you reinstall.
  3. Cyclops
    Cyclops Active Member
    371
    I've had one on my bike for 2 years, no problems. I'll have to monitor this post just in case. Best of luck.
  4. glider
    50
    Moving parts in the oil tank? Try cleaning the rubber stopper and the tank neck, then try it again.
  5. HDDon
    5,562
    133
    236
    I've had an HD analog unit in my '94 since '97 and it has never come out. I always dry it off before I reinstall. I know that there is about 30lb when the engine is at 2000+rpm and 12lb to 15lb at idle. You have to be very careful not to overfill the oil tank.
  6. Jack Klarich
    I know the manual says to lube it BUT maybe too slippery
  7. MilitaryMike
    MilitaryMike Member
    76
    Glider,
    Thanks for the response about "Moving parts", I just realized that I saw a thread talking about the 6 speed transmission dipstick versus the clutch cable.
    Thanks for setting me straight. One thing that I did notice between the stock oil dipstick and the analog oil dipstick is that the rubber is slightly larger in diameter on the stock version.
  8. 03hdfatboy
    03hdfatboy Member
    47
    Mine did the same thing and a friend of mine's done it also.What I did to mine and his was put a 1/4" fender washer on the dipstick, slide it all the way up and put it behind the rubber seal, it's a pain to get it up there but it will go. It don't come out anymore :D
  9. MilitaryMike
    MilitaryMike Member
    76
    Thanks 03hdfatboy for your response. Can you send me a picture of your Analog Dipstick with the 1/4" fender washer.
  10. Mad Dog Jim
    Mad Dog Jim Banned
    605
    5
    Just a thought... it seems to me that those dipsticks have a rubber boot that had fins on it to help hold it in the tank neck. (fins for lack of a better work) You might try taking it to Napa or some other auto parts store and finding an o-ring that fits sunggly over it, and thin enough to only increase the diameter a smidge.
