Amp gauge, how accurate?
Discussion in 'Touring Models' started by Ron41, Mar 24, 2010.
  1. Ron41
    Ron41 New Member
    3
    Ok, so I'm noticing that my amp gauge is always reading like 16 amps when I'm cruising, is it really charging this high? and if it is will this "cook" the battery?
    Are you referring to the "volt" gauge?
    If so normal voltage on this would be a bit above 14 volts when cruising. You may want to check the voltage at the battery with an accurate volt gauge.
  3. Breeze3at
    Breeze3at Well-Known Member
    4,923
    224
    The "volt" gauge on my '07 Classic is right around 14v cruising.
  4. tkeswede
    tkeswede Member
    76
    18
    MY 09 classic runs about the same. Upwards of 15 to 16 volts also. It never really changes. Everything seems to be ok. When I don't ride for a few days usually due to the weather I put the battery tender on it and it only takes a few minutes to top off the battery.
  5. nfusion
    nfusion Active Member
    143
    my 09 classic runs the same volts as yours i checked it with a meater and it is putting out about 14.4
  6. glyd-n
    glyd-n Junior Member
    406
    Mine generally shows around 14.4 when cruising. If showing 16 amps it may be overcharging. I would suggest to have the charging system checked out.
  7. Jack Klarich
    Like Glider said if you are reading volts you may want to double check that at the battery with a good volt meter, that is a high reading and it could kill your battery
  8. Dr. Dolittle
    6,404
    118
    29
    Best to leave it connected all the time - it's a tender, not a charger.
