free website stats program Alarm won't disarm | Harley Davidson Forums
Alarm won't disarm
longtimerider
Bought an08 Heritage classic,changed the battery and now the alarm won't disarm and allow the bike to start. Changed the batteries in the fob.Tried to retrieve alarm pin according to owners manual,didn't work. any suggestions?
I have read in previous posts that if you are going to disconnect your battery, you have to have your ignition turned on and then disconnect batt for maintenance or removal. That always works for me. I believe you will need to know the original code for your alarm and using the turn signal switches to get the bike to run again. Good Luck!!!:guitar
I moved this thread here, it may get more attention in the general forum. :s
Hi,
had a similar problem with mine a while ago, seemed the attitude sensor blitzed, try moving the tssm into a different position, mines now works mounted vertically??!
