Air intake
Discussion in 'Engine, Fuel and Exhaust' started by easyrider03, Jun 30, 2014.
  1. easyrider03
    easyrider03 New Member
    I want to install heavy air intake kit from Harley, will I need to get my bike re-tuned? It's a 2003 Electra Glide EFI.
  2. dbmg
    dbmg Guest
    YES...It will be too lean...............
  3. easyrider03
    I just purchased the Dobeck TFI, do I still need to go to the dealer for a re-tune or will the TFI take care if that?
  4. dbmg
    dbmg Guest
    You have all the bases covered with the TFI. Going to the dealer will be money spent that is not needed. You can get a lot of help in the self help section with setting TFI up if problems occur or contact their customer service. Enjoy the increase in power.:s
  5. Breeze3at
    Breeze3at Well-Known Member
    4,924
    224
    Odds are high if you go to the dealer with the tfi in place, they will try and blame it for problems you don't even have and try to sell you the HD download witch is still EPA compliant (lean). Spend a little time adjusting the tfi and noting differences in performance, heat and mpg. I'm satisfied with mine after 5 years with different cams, filters and mufflers.
  6. TQuentin1
    4,737
    142
    You might have been able to get away with just changing out the A/C without having to do anything to the fuel. But it would still be factory lean.
    If you change out both the A/C AND the pipes to ones that are much more free-flowing, you would definitely need to add fuel (fueler). That is where your TFI comes into play. Call Dobeck and let them know your engine configuration (A/C, pipes, cams, head work, etc.). Start with the recommended settings and then tweak as necessary based on how you ride.
    Glider had put a bunch of info in the self-help sections on the TFI, so search around and you will find lots about it.
    Cheers,
  7. Jack Klarich
