Air Horn & Cold Weather: If-fy Combo
Discussion in 'Electrical' started by RibEye, Feb 8, 2011.
  1. RibEye
    RibEye Junior Member
    993
    61
    For those considering an air horn...
    Just know that air horns do not like cold weather. They don't like to sing when cold. Once they have been warmed by warm jugs, they will return to singing, but intially, on a cold morning, you are likely without a horn.
    Enjoy,
    Rich P
    1 person likes this.
  2. lorne
    lorne Senior Member
    2,428
    58
    22
    good information, just about to put airhorns on. what temp do they stop working at?
  3. RibEye
    993
    61
    Mine (Stebel) don't like it at starting temp below 40. They wake up after riding long enough to get warm from the jugs.
    Enjoy,
    Rich P
  4. fin_676
    5,789
    153
    288
    At that sort of temperature if you try to make air move through a tight area any moisture in the air can freeze causing icing
    as the air is compressed it drops in temperature once the engine is hot some of that heat will find its way to the horn and prevent the icing
  5. ProF
    ProF Junior Member
    508
    Wouldn't matter to me. At those temps, my reflexes are so slow that I'd be splattered long before I thought to use my horn.:D
  6. RibEye
    993
    61
    Please note, I'm not complaining. My air horn is not going anywhere. When it works, when it is most of the time, it is superb. Just know that there can be a period of brief non-functioning.
    Enjoy,
    Rich P
