Air Cleaner hoses
Discussion in 'Engine, Fuel and Exhaust' started by Roklock, Apr 24, 2011.
  1. Roklock
    Roklock Member
    38
    Hello,
    I have a Pro - R Hypercharger air cleaner with three rubber hoses connected to it. I had it installed in Sept. '09 and this will be the second hose that I have had to replace due to cracking (dry rot).
    Is there an alternative to rubber I could use? Maybe a braided stainless hose? Currently the rubber is clamp fast to each end using wire ties which might be a limiting factor when considering other hoses?
    Any input is appreciated.
    Thanks,
    Steve
    You may try some fuel line for model airplanes available at most hobby shop. It also comes in colors.
