Air cleaner conversion
Discussion in 'Other Service and Maintenance' started by purplehazer, Jun 7, 2015.
  1. purplehazer
    purplehazer New Member
    I have a 2002 dynaglide that has a Mikuni carb instead of the stock Kein.(forgive my spelling).I bought a "Screamin Eagle Pro Heavy Breather Kit".
    (Part # 29098-09).Iv'e been told that this will not bolt on due to difference
    between the two carbs. Does anyone know if there is an adapter to make this
    work or am I stuck with a brand new Air Cleaner. If so I will sell it to whom
    ever can use one..
    Thanks,
    Purplehazer
  2. fin_676
    5,779
    153
    285
    There is an adapter available to use the stock type air cleaner back plate with the mikuni hsr carb it comes as part of the easy kit's and can be bought as a separate item
    I use one on my dyna which has a hsr 42 carb and a screaming eagle air cleaner
