free website stats program air breather | Harley Davidson Forums
air breather
bobrobert
I have a 2010 street glide and oil is coming out the air breather...i would appreciate some tips in why its doing that?
thank you
thank you
Just do an oil change? Too much oil, check the hoses coming off the heads to the back of the filter some times they collapse, some have oil pump misalignment problems. When changing oil try at least half a quart less than book calls for, the crank case holds up to 1 qt of old oil
crankcase breaths thru it and somtimes spits some out. make sure u dont have too much oil in it tho.
i sure will...is it ok if i wait til spring to change the oil...the bike is now laid up for the winter, i live in canada?
well most say tis better to change b4 putting up for winter so all the junky oil dont sit in there and corrode
