Adjusting shocks on 13 Heritage?
Discussion in 'Softail Models' started by Rafaelw, Apr 2, 2014.
  1. Rafaelw
    Rafaelw Member
    50
    Wanted to adjust for passanger driving , dealership told me they shouldn't be adjusted?
    [​IMG]
  2. TripleJ
    TripleJ Senior Member
    1,081
    8
  3. coopernicus
    coopernicus Junior Member Contributor
    968
    97
    Just read your owners manual and don't go more turns than the reccomended settings. I also have a 13 heritage and mine was way too stiff when I bought it.
    I adjusted mine down with no problem. I just put a piece of tape on the cylinders so I tell how many turns I made. Also, I did it with the bike on the side stand.
  4. Billbo
    Billbo Junior Member
    717
    8
    I have posted on here about this same thing earlier. I REALLY have difficulty (read impossible) to adjust the shocks on my 2001 Heritage. I wont rewrite all the other posts here but I will re-state -- the spanner wrench would NOT turn without hitting the frame. Plus the holes are at 0-90-180-270, so you can ONLY turn shock in quarter turn increments. HOW did you adjust your shocks.
    Thanks so much,
    Bill
  5. Rafaelw
    Rafaelw Member
    50
    The dealership stated its not a good idea because they have seen cases where something broke,, i dont recall the exact wording they used, but just said they should be left alone how it came from the factory. I do not understand IF they are adjustable, and the manual says it's ADJUSTABLE.
  6. Jack Klarich
  7. Bodeen
    4,643
    73
    221
  8. Rafaelw
    Rafaelw Member
    50
    Thanks for all the info .
    [​IMG]
  9. coopernicus
    968
    97
    I don't know how an 02 is but here are a few pics of mine with spanner wrench attached to shock. Before you attempt to turn shock, you have to loosen the big nut right in front of the shock. To loosen the big nut you have to put a wrench on the little nut in front of the crossmember. I think I can only turn at quarter turns also, that's why I put a piece of tape on the shock. So I could tell when I went a full turn. Had to wear a thick leather glove to turn the spanner wrench cause it digs into your palm pretty hard. Hope this helps.
