Activation Code 99 - What to do?
Discussion in 'Electrical' started by nuker02, Aug 13, 2011.
  1. nuker02
    nuker02 Member
    6
    I have an 02 FLSTCI with the check engine light on. Bike is stock and runs fine. Bike does not have a security system on it. Light came on 2 days ago while riding. It has a code 99 - password problem. Any idea what causes this and what to do to correct it?
  2. HDDon
    5,544
    133
    229
  3. nuker02
    nuker02 Member
    6
    Unfortunately this thread just has a code 99 in the list as a password failure. I was looking for information on how to correct the problem.
  4. HDDon
    5,544
    133
    229
    Since you stated that your bike does not have a security system, if you read the text the code will go away after 50 cycles of the ign. I think the only other way to get rid of it is to have the dealer cancel it.
  5. nuker02
    nuker02 Member
    6
    Thanks for the reply HDDON.
    Since the check engine light stays on all the time I am assuming the code is a current one and not a historic code. If I am correct the check engine light will never turn off until the problem is fixed. That is why I was looking for advice on how to correct a code 99 (missing or incorrect password).
    I saw some posts on marrying the TSM system, but that may not be related to this. I read that the "password" is not really a password but more of a system component recognition complete signal. I don't know why mine would have changed after all these years.
    The bike is running fine, so I am reluctant to try the marry procedure if it is not the correct thing to try.
    Any suggestions on how to correct the password?
  6. nuker02
    nuker02 Member
    6
    Found a solution for getting the current code 99 (password problem) to cancel and now become a historic code.
    I found a thread by Glider that was related to a TSM malfunction.
    Glider's post was listed as "Missing Password".
    I took the fuses out for 10 minutes and then put them back in and turned the ignition on. The check engine light comes on for a few seconds, then off for about 2 seconds, then on again for about 2 seconds and then goes out and stays out. Now it must just be logged as a historic code and will eventually clear after 50 starts.
    If you see this - Thanks Glider.
    :D
  7. HDDon
    5,544
    133
    229
    Now you know why he is our go to guy!!! Way to hang in there and get the problem solved.
  8. TripleJ
    TripleJ Senior Member
    1,081
    8
    Any takers that he won't??? :D
  9. glider
    I eventually will see it all given some time :D
    Glad you found the solution, it's all posted here over the years I've been here, all it takes is persistence and searching. :cheers
    Now if we could get everybody to try a search, we'll be doing good!:D
  10. HDDon
    5,544
    133
    229
    Don't be so modest old friend. 95% of knowledge is knowing where to find the information, but the information has to be there to find!!
