free website stats program accessory power wires | Harley Davidson Forums
mtrbrth3
wanted to know if there is any accessory power wires underneath that i could hook my gps to_On my other concours it had two bullet style connectors that was plug n play as well as a 12v dc outlet also there is no dipstick for the primary oil? my owners manual just shows how to change but not check the primary oil.Thanks in advancebtw it is a 2011 flstc.
Not sure on your power outlet, My 2010 RK has one under the seat.
The primary oil is to lube the chain. there is not heat so should not cook off. The only way it should be low is if there is a leak
