Check the wires coming out of the switch. you may have to trace them back and see if you have pinched or nicked wire that keeps grounding itself.
you may want to look to see if your front fender light is working as the wiring runs along the inside fender and could be nicked.Also the harness goes through the rear fender and can have contact from the tire as it did on mine and caused mine to blow .Id been running around with no brake lights.
