Regain Control of Your Fuel Injected Ride!
AUTOMATIC RE-CALIBRATION - optimizes for modifications such as exhaust pipes, intake, air cleaners, cams, etc
EASY INSTALLATION - direct plug-in connections to factory Throttle Position Sensor, Crank Position Sensor and O2 Sensors
SMOOTHER RUNNING ENGINE - Eliminates the “bang & pop” associated with mis-programmed ECU due to intake and exhaust modifications and no need to re-flash the factory ECU; simply plug it in and ride
