A Stupid Question of Very Little Import
Discussion in 'General Harley Davidson Topic' started by gasbag, Jun 12, 2011.
  1. gasbag
    gasbag Active Member
    356
    I rarely ride with others, mainly because I have no friends and no one loves me.:bigsmiley15:
    However, I ride with my son every time he comes down to visit. He has a V-Rod, stage 1, V&H pipes, tuner and dyno tuned. Sounds very good.
    I have an Heritage, same package except SE II pipes. Also sounds very good.
    When we ride together and our rpms get close to each other we get an exhaust sound sort of like a "waaahwaaahwahwahwahwaah" vibrating between us. Kind of an echo sound. It's weird.
    Anyone know what that sound is called and what is causing it? I am curious.
    See? I told you it wasn't very important and yet you read all they way down to here.
    Well, thank you.:worthy
  2. av8rjim84
    av8rjim84 Member
    30
    This is a phenomena in physics called Harmonic interference. Some harmonic interference cancels each other out, like when you put on one of those fancy bose headsets and it cancels out the noise. In this case what you are hearing is an amplification of the sound caused by your two pipes resonating at the same time. Because they are still a little out of phase (not exactly the same and occuring at the same time) you hear that wah wah sound. Some of the time they amplify each other and others they cancel each other. If they were both exactly the same wave form and in phase, you would hear an extremely loud version of each of you, and if they were 180 degrees out of phase and the same wave form, you would hear a much quieter version of the two sounds, as they would cancel each other.
    Correction: Called Wave Interference, not harmonic interference. And it is either constructive or destructive.
  3. Rhys
    Rhys Active Member
    151
    I will take the bait. When I ride with my buddie the same thing happens, and we have actually talked about it. if we run side by side it does the wawawawawa your talking about, but if I change the rpms just a bit it goes away. I belive the two bikes together hides the exhaust pulse that you would hear from just one bike or riding at a further distance from each other. Its blending the two sounds together, thats just my two cents!!:newsmile011:
    Thats what I was trying to say!!!:laugh
  4. av8rjim84
    av8rjim84 Member
    30
  5. opaka lips
    opaka lips Member
    52
    I'm not sure if this is the same phenomena but I think it is: My boat is powered by 2 outboard engines. I get the same (waaawaaaa) sound if both engines are not adjusted to the exact same RPM. By carefully adjusting the throttle on one of the engines I can eliminate the sound, which tells me that both engines are set to the exact RPM. The RPM guages confirm this. I've never experienced it when riding with a buddy, but will try and achieve the same effect next time I'm riding with a friend. Very Interesting!
  6. wilks3
    wilks3 Junior Member
    623
    Here I thought it was a Beatles song.
  7. Alamo
    Alamo Member
    It is the harmonics of Harley Davidson. It is the harmonics of life. Do not try to understand it. It is mystic. Just enjoy it. Ride easy.
  8. gasbag
    356
    Thanks for the replies folks. Like I said, it is weird and I was curious.
    There are some smart people in here.
    And then there is me. Oh well, someone has to occupy the right end of the Bell Curve.:bigsmiley22:
  9. Bodeen
    4,643
    73
    221
    Great advice!
    Bodeen
  10. Billbo
    Billbo Junior Member
    717
    8
    Just about the same as tuning a guitar. Two strings - same note - out of tune sounds like a "wahwahwah" going on when you strike both at the same time -- git ur in tune - the wah wah goes away. Note this wah wah gets faster the farther away from IN TUNE you are and slower the closer in tune you get. Therefore, the answer to you question is simple - get the two bikes 'in tune' with each other and no more 'wah wah' :):):)
    Bill
