A little rust on Chrome what should I use
Discussion in 'General Harley Davidson Topic' started by peteG30, Apr 25, 2009.
  1. peteG30
    peteG30 Member
    22
    Just picked up my brother 00 FLHT 25K miles but it has a little rust on the chrome bag guard etc. I'm thinking of trying out Mother's Mag Polish, What you all think, any other suggestions? Cant afford right know to Re-Chrome..
  2. a1scoot
    a1scoot New Member
    4
    Pick up some 0000 steel wool (ultra fine) at a hardware store.
    Really, It works fantastic and will not scratch the chrome in any way.
    Give it a try..
    I have been using it for years.
    a1scoot:D
  3. Apyle
    Apyle Junior Member
    540
    I was able to bring my chrome back with steel wool and wd-40.
  4. 00BUCKSHOT
    00BUCKSHOT Junior Member
    446
    after the steel wool use semi-chrome polish i had the same problem on a sett of pipes once and that combo fixed them right up!
  5. hntwrobin
    hntwrobin Active Member
    236
    Never Dull or Luster Pad both are similar and work well:14:
  6. JimmyZ
    JimmyZ Member
    A soaking wet SOS pad used very lightly will remove small specks of surface rust........
    It will work on deeper rust but several applications are needed.
    Rub very lightly and gently each time being very careful not to scratch the chrome. Also don't use the pad after the cleaner is used up in the pad
  7. NEWHD74FAN
    8,191
    98
    19
    Do not use steel wool on chrome...very small microscratches will give it a satin finish...:devil
    Never dull or chrome polish works, followed up periodically with Pledge does the deed nicely. :p
  8. STEVE07
    4,125
    68
    84
    Use Jewelellers polish #4.
  9. Bubbaglide
    Bubbaglide Member
    67
    I had heard once that you take a piece of aluminum foil and run the affected area. haen't tried it but who knows/ Who first thought of putting Pledge on your motorcycle? It works too !
    Ride safe
    Bubba
