97' Road King
Discussion in 'Touring Models' started by scottlooper, Jul 11, 2009.
  1. scottlooper
    scottlooper New Member
    Thinking about buying a 97' RK. I have heard that this years model had a noise coming from the tranny in 4th through 6th gears. Any reason to worry about this and does anyone know of any other problems associated with this years RK...
    Thanks.
  2. Flashback
    Flashback Active Member
    294
    a 97 should only have 5 gears unless someone upgraded the box. The only noise I know about was on the 07 5th gear whine. can't remember but I think the 97 was still a 80" evo they had trouble with the 88" twin cam cam tensioners but like I said I don;t think the twin cam came out till 98 - 99 so you should be good..
  3. glider
    50
    97 is an evo 5 speed. The 5 speeds did have some noises associated with them being straight cut gears but nothing to worry about.
