'97 Breaking Rear Spokes
Discussion in 'Softail Models' started by Dr.Evil, Apr 19, 2010.
  1. Dr.Evil
    Dr.Evil Junior Member
    694
    5
    Friends 97 brakes rear spokes even after some were replaced and the wheel was trued. They brake at the hub. He is thinking the hub may be worn out.
    Any Ideas?
  2. HDDon
    5,544
    133
    229
    I have only seen spokes sold in sets. Why would you only change some of them out?
  3. Dr.Evil
    694
    5
    How can I answer that question.
    Still asking for useful information, could it be the hub or bearings.
  4. glider
    Possibly over tightening the spokes will cause breakage.
  5. BUBBIE
    BUBBIE Well-Known Member
    4,974
    125
    I like tapping with a small wrench to hear the sound Or TUNE the spokes play... This will usually tell if too tight or loose. I like the tones to be = to each other and not too flat nor too high a pitch...
    "Thawng" not "donk"(loose) and a little like "Tink" but even in pitch all the way around..
    just my way.
  6. Breeze3at
    Breeze3at Well-Known Member
    4,926
    224
    Even after some spokes were replaced, many of the remaining spokes suffered stress, and are now breaking. Even if rim runout is within specs, it could have been trued too far left or right and putting uneven pressure on the spokes.
  7. glider
    Suppose you get a "Dink" or a "tonk" ? What does that signify? :newsmile100:
  8. BUBBIE
    4,974
    125
    I check a Bran-new HD bike in Texas at the ROT rally. A fellow rider bot new bike for his wife to ride out there as it came off the show room floor...
    The gal complained of the vibration and just a BAD ride above 60/65 and was afraid to ride it any where near the 80 mph allowed on the freeways..
    A mutual friend mention ME to them and said I knew my "stuff"... Boy, No Pressure put on me at all... WITH THEIR CONSENT and witnessed by many.. I said okay... I'll check you adjust.
    I simply got out a small wrench and tapped the spokes 11 in a row on the rear wheel and on one side were flat,dull, and just no tone at all... The front was even worse..( we had no way to raise the bike so tuned this way was a try and see)
    I explained the problem and the OWNER took my advice and tightened them according to the tone procedure and took the bike out for a spin.
    Came back with a smile and said it was a different bike.... No vibration and smooth!
    I also explained that this was a temporary fix and should be tuned-trued by the HD shop when he got it back in for the first service..
    just my way.
  9. Dr.Evil
    694
    5
    Thanks, I will recomend a new full set, a better quality install, and to check the tuning more frequently.
  10. BUBBIE
    4,974
    125
    AH, com'n Glider, Everybody knows you get those Sounds from a Metric bike!
