96 FXSTC starts on front cylynder then...
Discussion in 'Softail Models' started by Brainj, Sep 4, 2011.
  1. Brainj
    Brainj Member
    7
    (EDIT) ! My 96 FXSTC will intermittently run on 1 cylinder. The front cylinder always fires but the back will go in and out. I replaced the plugs and wires.
    It will start on the front cylinder, then the back will kick on after a while. then the back will go out again. Has anyone had this problem? Please help.
    Please read this...
    [note]
    [/note]
  2. HDDon
    5,562
    133
    236
    Have you changed from the stock duel fire ignition? Has anything been done to the bike recently?
  3. Brainj
    Brainj Member
    7
    The engine is stock.
  4. glider
    50
    Have you checked the ignition coil yet?
  5. Brainj
    Brainj Member
    7
    It was tested and was good.
  6. Hoople
    Hoople Account Removed
    7,198
    34
    When it goes out, how long does it remain out. How did you determine it is the rear that goes out.
  7. Brainj
    Brainj Member
    7
    It goes out for about 3 minutes then on for a while then out for a few minutes. it will start on 1 cylinder then the front will kick in. The rear is cold until it kicks on.
  8. HDDon
    5,562
    133
    236
    Running for three min, are you fouling the rear plug?
  9. glider
    50
    You have 2 into 2 exhaust on that bike from your picture. Try covering the rear exhaust pipe when it's not firing and hot and see if you can feel the compression from that cylinder or if it's lacking. Possibly a hanging valve.
  10. Hoople
    7,198
    34
    Save me the trouble of looking it up. :)
    Would you know if your ignition system (which you said is factory STOCK) is single fire or dual fire,,, And do you have a stand alone CAM trigger, CRANK trigger or Both.
