95 Heritage not starting up. battery has been on trickle charger. I turn ignition but the lights go low and then the battery dies out. Like it's not pulling enough amps to turn the starter. Battery has been tested to hold load. The solenoid gets real hot when I make several attempts. One time the ground wire (mounted on to frame) started smoking. What should I check first?
