90' tire valve stem
Discussion in 'Wheels' started by kemo, Oct 20, 2010.
  1. kemo
    kemo R.I.P
    1,690
    5
    I thought that I would try a 90' valve stem the next time that I changed a tire so I did. Mistake, the stem doesn't clear the brake caliper so I turned it 180' so that the cap is on the belt side but the pulley makes it a bit awkward to check tire pressure. It is done now but next tire change it will get undone. Just thought I would mention this in case you thought of doing it.
    kemo
  2. HarryB737
    HarryB737 Junior Member
    656
    Wow... I don't think I've ever seen a 90 foot valve stem :newsmile100: ,Seriously though thanks for the info.
  3. bobwire
    bobwire Active Member
    116
    been thinkin bout it myself. thanks for savin me....................bw
  4. Jack Klarich
    Think I saw them on Gold Wings:s
  5. trvlr
    trvlr Junior Member
    424
    Yep, they're on there - actually had the same thoughts as what Kemo did - so appreciate the heads-up on that.
  6. dbmg
    dbmg Guest
    Thanks for the heads up Kemo
  7. NEWHD74FAN
    8,191
    98
    19
    Personally like the shortest stem possible that allows you to fit most air chucks (or carry a small stem extension that works with your guage). That way, less balance weight impact and less profile to catch or snag. I do use metal cap with seal inside, less chance of leakage (also keep insert wrench to make sure the inside valve is tight) after checking air pressure and sealing with cap.
