I disagree with the rest of the people about choosing the lower compression. When I first did my conversion to a 1200, I went with the 10.0:1 1200 kit. Kit that I purchased included the reverse dome pistons, pins, gaskets,rings etc. 10.0:1 compression is not going to be an issue considering the gas, if you use premium (at least 91 octane).
In my opinion, I did not like that set up by itself. I opted later to go with a set of SE heads, SE cams, (.497), 10.5:1 SE flat top pistons, bored .005 over, SE perfect fit push rods. Now we are talking about some power. Up to you. OH yeah, almost forgot, I put an SE selectable ignition with SE coil, and plugs. Questions?
