883 R oil leak
Discussion in 'Other Service and Maintenance' started by rdh1145, Apr 30, 2009.
  1. rdh1145
    rdh1145 New Member
    I have a small oil leak from the rocker box on the real cylinder. Just enough to make a puddle on the engine cases , leaks when on side stand until oil is gone from box.
    Is there any way to fix this with out dropping the motor to replace gasket ?:eam
    Bike runs great , about 13000 miles , never any problems other than the oil leak. Seemed to get worst when I changed oil and used Syn 3.
    Appreciate any info !
    Ron
    You can get to the bolts but it is very close without moving anything. It's possible to unbolt and remove the front mount to gain a bit more room. Not the easiest job but can be done without much problems. Just make sure to use quality seals when you do it , check for any warping in the covers and torque the bolts properly when you replace them.
  3. fin_676
    5,779
    153
    285
    If your bike has a solid mount engine it was fairly common for the lower rocker gasket to leek oil
    gaskets can be changed with the engine in the frame but it is difficult to get to some of the bolts but there is just enough room to do it
    lower gasket should be one piece metal gasket the two peice paper one did all the leeking
    read the task up in the service manual not a difficult job at all can be done in a couple of hours
  4. R. Lewis
    2,183
    5
    What kind of oil were you useing???
  5. rdh1145
    rdh1145 New Member
    The bike had 20/50 Harley oil .
    I have been using Syn . in my Road King since they started selling it . I bought the 883 used and have put about 3000 miles on it . When I got it , I could see a small trace of oil on the case below , it looked like it might be seeping down there . It never leaks enough to drip on the floor , but it is worse.
    Thanks to all for the feedback
