free website stats program 883/1200 heads | Harley Davidson Forums
883/1200 heads
steve299
Stupid question, but I have to ask it. If you can use 883 heads on 1200 pistons can you do the reverse and use 1200 heads on an 883.
I found a set of brand new SE performance heads and wondered if I would get any benefit from them vs my stock heads.
If I were doing this conversion, I would only go with like jack said: use 883 on a 1200 conversion OR convert to 1200 pistons and cyls then use the 1200 SE heads...
I have done the 1200 conversion and used the 883 heads and Built me a very fast bike..
Google; Jerry Branch, one late night with jerry branch; BUBBIE
Here it is.. Read this and you will learn.:bigsmiley23:
Search Result - Harley Davidson Community
Have fun with that bike no madder which way you go... (smitty901)
If you use the 1200 pistons and the 1200 SE heads,,, Wow,,,, HOLD ON :D
especially with 10:1 or 10.5:1 pistons.
The 883 bike is geared lower so it will WILL fly.
If you have a new rubber mounted motor in FI trim the stock heads on the 1200 are good, if you want real performance head see NRHS performance they do some stunning packages, me I would if i had a 1200 sporty leave the heads alone unless I was doing other work to the motor
Hobbit used to KNOW all these answers TOO,,,, Just Like lucky 15...:bigsmiley23:
