F FXSB New Member Apr 19, 2010 #1 WHEN YOU TOURX your sprocket on should you be able to move the main drive gear in and out slightly ????
J Jack Klarich Guest Apr 19, 2010 #2 FXSB said: WHEN YOU TOURX your sprocket on should you be able to move the main drive gear in and out slightly ???? Click to expand... .oo3- 009 end play hope this helps
J Jack Klarich Guest Apr 19, 2010 #4 FXSB said: what do you do if you have more Click to expand... You can buy thrust washers of varying thickness from the Stealers for the mainshaft and the counter shaft
